Discuss How long should it take to fit a Europrisma 10 ltr 2Kw u/s water heater? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Phillips wife
Hi there,
I am a newbie to this site, so apologies if this posting has found its way to the wrong place.
I had an under sinkwater heater ( Europrisma 10 ltr 2kw) fitted to a refurbished one bed rental ground floor flat. The cold feed was within a metre of the position of the heater and it DID need a pressure release valve fitting as our pressure was 5 bar? The hot went to the sink, obviously, and another hot went to an en suite less than 3 metres away. How long should this have taken?
We chose this water heater because all the reviews rated it highly and said it was easy to install. Our plumber has charged for 16.5 hours and part of another day of 7 hours, so potentially it could have taken 23 hours. Am I missing something?
All advice would be very gratefully received.
The flat is small and the " kitchen" is just 4 x kitchen base units wide, our plumber said it was fiddly, but surely all under sink water heaters are fitted in a small space?
I telephoned the Ariston helpline and they said "one day max for fitting"
I do hope you will be able to advise.
kind regards,
Mrs Phillips
How long is a piece of string. Without seeing the job its impossible to say. Did it need an expansion vessel, pressure relief valve to be drilled out? Too many variables.
As above, without seeing the job it's hard to say....
Was a new electrical supply needed, was the pipework route to the ensuite torturous, was the PRV route a nightmare, was fitting the pressure reducing valve to your incoming supply a pain etc etc.
Well. We fitted a 100l unvented and it took 2 hours to fit the water heater. 3 days to install new supply and upgrade 3phase consumer unit. It was on external wall and no issues and not in a unit .
The same length of time it will take to you to fix my car ;)
You have no idea what the issue is, what car it is, what parts it needs, where the car is, where the keys are to access the car. The list goes on!
Ask to speak to the plumber as to why it took so long and a good plumber will give a brief explanation
From my learnings no one job is ever a 'straight swap'. I have had baths out to 'straight swap' taps. Labour was more than the taps!
23 hours does seem long. But then that could be really quick without seeing the job. What's his hourly rate
You say you bought the heater based on its good reviews. What made you go for that particular plumber?
Mrs Phillips, they can be an absolute ***, I hate doing them.
As everybody has said its hard to comment without seeing the job.
But to be truthful,it does sound like a lot to me
Im sorry guys but 3 days to fit a heater , sorry doesnt matter if he had big hassles 3 days is an absolute disgrace ( in my opinion) , the cold was there , elec there, even if he had to run pipe outside for a press relief and fit a ex vess its still way tooo long, but thats just my humble opinion
What if the units were extremely difficult and expensive? Perhaps a day 1/2 but without seeing it...... Multiple trips to merchants
Thats reasonable with hassle erms , but 23 odd hours seems a tad long dont you think,,
I think one plumber is either takin the **** or he really didnt know what he was doin , its just a shame for the customer because even @30ph thats 690 plus materials ouch n thats not inc heater , oh dear John Wayne
No way the job was on an hourly rate...... Doh! Missed that bit. U been had me thinks
2 hrs max - 2 long flexi hose connectors, 13a plug on a bit of wire and run the PRV discharge into the floor void - job done
She is on tilers forum moaning about the cost of some tiling professional moaner/non payer me thinks.
You should have asked for a price on the job. And any plumber worth his salt would have come, looked at the job PROPERLY, taken into account any awkward hurdles he may have had to overcome and priced accordingly. Then you could have taken or leave it and /or got another quote.
Perfectly said.
Reply to How long should it take to fit a Europrisma 10 ltr 2Kw u/s water heater? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I'd love some advice on my system, I've had a couple of plumbers come in that seemed to specialise in gas systems and seemed perplexed by my all-electric systems and the issues I'm having. My system is all electric heating and hot water system, in a flat on the 4th floor. The mains...
Hi, I'm renovating (rewiring electricity, redoing and adding water pipes, gas pipes, moving walls) a house for the first time ever and, among other things, I will need to sort out hot water. Understandably, I have some questions. It's a very small house currently with only a kitchenette...
1K
Not sure if this is a success or a fail or just a rant but We do have heat and hot water now So all started the evening of Friday the 12th (Nov) I had noticed the water wasn't getting hot nor the heating. We had someone come have a look the next day thinking it was something simple like the...
2K
Hi all This is only about my third/fourth post, so go easy. Also, I'm only an enthusiastic amateur, not a pro... I'm having issues with the waterboard and can't work out what's happening. For the past three months, they're saying we're using a huge quantity of water - 700 litres per day at...
2K
Hello All and thanks Lou i did write a reply but it would not let me send it? i am not sure what I am meant to write and I do not want to come over the wrong way so please keep in mind I am 57 and at school in the 70s back then was kicked out the lessons and put in remedial classes (before...
