Discuss How long will a repair last using Denzo tape in the USA area at PlumbersForums.net
Doreen
Hi how long will Denzo tape last on a pipe repair it’s the large pipe we’re it enters the house just above ground level in ground floor toilet. Council say it will last years this was repaired 6 years ago. Thinking of buying the house but this is a major concern. As the deviation it coursed was horrendous
If your buying it insist on it getting repaired or replaced
:D I hope that’s a joke
Reply to How long will a repair last using Denzo tape in the USA area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
