Discuss How many have you lot changed? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
quality
5 but they were on the same estate
I have replace the inspection cover on 2 occasions and its been the sump thats cracked so I just replace the whole sump on them now to be certain. Pretty bad really as I have done quite a few
Whats involved in changing the sump ?
None yet, had a couple done under the Ideal warranty, done a few seal, and 1 manifold, but no doubt, it won’t be long!
Not much as it just clips on, getting the old one off can be a pain if you've never done it before
I have never done one because all my customers have combis and from what I have heard they only go on heat-only’s
Ive done more on combis than heat only but then thats probably because there's more combis than heat only out there
Done one. Was quite easy. Just loosen the heat exchanger holding screw slightly to ease the back clips.
Reply to How many have you lot changed? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks ok to me.....sound but the bowl has seen a lot of work. So she wants a new one...Astracast it seems are no more. The problem is its size.....looked...
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
