Discuss How many holes do you get? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jaydebruyne
how many holes (roughly) you get from a 5" diamond core bit? Mines an erbauer from screwfix.
Normally if there cheap 10-15 but as last said if you have a few hard ones will shorten it to manybe 5-10
That explains it then lol. Took ages to get through 1 brick. Bought a new bit and got through the other one in 10 mins!!
Aye depends what you are cutting. Mine seem to last well, but a lot of sandstone round here and easy cutting.
I have never counted to be fair. But mine is on its last legs now. I think that it is a Marcrist. But I have had it about 3 years. But I have been lucky and cannot actually remember the last time I used it.:D:D
Yeah I've not counted either but I reckon it's around 10 or so..
Never rated the erbauer core bits. My last set was a Rothenberger one, which lasted quite well. Had Marcrist as well before which are very good. As for the number of holes, I wouldn't have a clue. But I would estimate at 40+
Bloomin eck 40 ain't a bad number..
Using the right drill makes a big difference, most of my kit is Marita, but core drill is a dewalt , can't fault it.
iv not counted but id say about 20 if i dont keep drilling though the metal cladding as well
I've done that before.. spent most of the day getting through that
My core drill is a Makita, it's done me well. Not a fan of Dewalt. Only Makita tool let e down was a percussion drill. Have sent it for repair twice!
A good core should do 50+ holes easy aslong as your drilling fairly hard bricks. Alot of soft bricks are very abrasive and wear down your bit very fast, 10 holes on those bricks is good
Reply to How many holes do you get? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
