Discuss How much joist can be cut out fo CH pipes in the Central Heating Forum area at PlumbersForums.net
I know a joist is a joist but it is parallel to a brick wall not perpendicular when obviously they carry a greater load. Can the joist not be fixed solidly to the wall with packing between either side??
Not sure why people are so fond of bending copper pipes rather than using elbows. It seems to be a UK thing.
As someone said previously, just use elbows to get rid of those silly "bends" and you'll be good to go. All that is needed is a 3/4" deep notch in that joist, too bad you can't put the wood back, but as the joist is against a brick wall, I doubt it will be problem.
Love the scorch marks on the bottom of the floorboards, doesn't the guy have a piece of alu or tin to put behind there to prevent that?
The reason we prefer bending to using elbows is because we’re plumbers and we like to show it sometimes!
Not to mention the better flow properties and reduction in noise...
Reply to How much joist can be cut out fo CH pipes in the Central Heating Forum area at PlumbersForums.net
Sonya K
