Discuss How much movement need there be... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
Subscribed
In the pipework tails left sticking out of the wall to fit shower brackets like these:
I've not fitted any before but am guess that you have to do up the compression connection at the back and then push the pipe back into the wall to make the bracket flush so you can then drill and fix to tiles..?
So sounds like you need to leave quite a lot of play and therefore presumably not clip the pipework.
you dont need any play, this image should give you a better understanding
Ah wonderful news. You've made me a very happy man. Since I'd already clipped the pipework and tiled the wall before the thought occured.
the ones i have fitted needed cutting around 35mm from finished wall/tiles. just make sure centers are correct and level and tile around them leaving a few mm max.
make sure the copper is not protruding past the chrome thread as some shower with filters/flow restrictors wont go fully back without comlications.
i think these kits are great, mean you can change the shower valve in 5 mins in future.
Some showers come with them, they all should really. I mean how else can you fit a bar mixer to a solid wall properly?, those offset elbows fill my scrap bin up nicley.
Fitted one the other day in a bathroom, solid walls and tiled etc. After grouting I took my speedfit caps off and cut the pipes without thinking with the pipeslice hard against the wall! wasn't thinking........I just got away with it and the olive was just on the end of the pipe, luckily though the design would not allow the thing the blow off or leak.
Fitted loads of them aswell.
Reply to How much movement need there be... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Size of bathroom 230cm x 210cm Height 230cm Birmingham Area Initial problem Burst pipe underground in bathroom, concrete. Have had this dug up...
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes...
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old fittings, and old wall tiles and floor carpet). This...
Hi, hope all is well! I’ve fitted a compression cap on two of my shower mixer copper pipes (15mm). One of them has scratches and burring and is...
Hi everyone. I'm installing a walk in shower, opening into shower will be on right, mixer value on right, but shower head and drain on left. The...
1K
