Discuss How much...? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jacqus
How much would it cost to do all the following:
unblock a bathroom sink
change an outlet pipe
fix a tap that is turning slowly with little output?
Please help, as I need to work out my budget.
Thank you
They're all a bit how-long-is-a-piece-of-string jobs. Each can go quickly and easily or be a pain in the rear. Very vague ballpark figure 1-3 hrs, 1hr = £40-60 depending on who you call and where you live, 3 hrs £80-£140. Plus parts. Which may or may not include new taps.
Reply to How much...? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm a council tenant and my bathroom basin is broken and needs replacing, it has standard pillar taps. Do you know if councils would ever replace it with a mixer tap one if I paid the difference? (I'm guessing no but it's worth a try). How much more complicated and time consuming is it to...
I have a problem with noise and vibrations from my shower when i first turn it on. The problem lasts for about 30 seconds after the shower is switched on before it stops. There is a sink nearby, sometimes if we switch that on slowly before turning on the shower then the shower doesn't make a...
60's ranch, with single bathroom. Tile over concrete slab. Toilet is about a foot from exterior brick wall. Vent pipe is in interior wall behind toilet. There's a concrete patio outside the bathroom, that extends about 10 feet from the wall. I'm considering adding an ADU in the back yard, and it...
Hi I've recently had a new bathroom installed. I've noticed when I flush the downstairs loo there was a hammer type noise under the bathroom floor when the cold feed for the loo turned off/ same with the washing machine. So I turned off the mains water supply. Opened the highest tap first...
J
I own a top floor flat in a 4 storey block, i bought it 3 months ago (meaning that this is an issue i will have to personally deal with, no landlord). at first i had no issues, but recently, we have no warm/hot water in our kitchen or bath taps. the bathroom sink hot tap gets warm, and the...
Deleted member 120897
