Discuss How much...? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jacqus
How much would it cost to do all the following:
unblock a bathroom sink
change an outlet pipe
fix a tap that is turning slowly with little output?
Please help, as I need to work out my budget.
Thank you
They're all a bit how-long-is-a-piece-of-string jobs. Each can go quickly and easily or be a pain in the rear. Very vague ballpark figure 1-3 hrs, 1hr = £40-60 depending on who you call and where you live, 3 hrs £80-£140. Plus parts. Which may or may not include new taps.
Reply to How much...? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm a council tenant and my bathroom basin is broken and needs replacing, it has standard pillar taps. Do you know if councils would ever replace...
I have a problem with noise and vibrations from my shower when i first turn it on. The problem lasts for about 30 seconds after the shower is...
60's ranch, with single bathroom. Tile over concrete slab. Toilet is about a foot from exterior brick wall. Vent pipe is in interior wall behind...
Hi I've recently had a new bathroom installed. I've noticed when I flush the downstairs loo there was a hammer type noise under the bathroom...
J
I own a top floor flat in a 4 storey block, i bought it 3 months ago (meaning that this is an issue i will have to personally deal with, no...
Deleted member 120897
