Discuss How stiff is 15mm copper coil in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Anybody familiar with 15mm copper off coil..
I need to supply a shower through a couple of joist holes.
plastic would would be easiest option but customer would like copper if possible
Just wondering how stiff it is to work with ?
Not too bad 22mm is a bugger
I was thinking it work hardens , so if can get it right in one !
( - stiffening a little each time it's bent more - )
Copper tube does indeed work harden. You can also anneal it with a propane torch. You'd need to buy some, experiment, and then (I predict) decide to do it in plastic.
If you were lucky enough to be able to drill a hole in outside wall, or in extra joists if next room has joists running the opposite way, then you can feed ordinary straight copper lengths in easy.
Otherwise straight copper just will be about 14" max between 16" centres joists and solder connectors to use.
The 15mm copper coil is difficult but not impossible to use for a short piece. Take it slowly and with gradual slight bends. Drill the joist holes extra big also.
Reply to How stiff is 15mm copper coil in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
