Discuss How to check heating elements in Triton T30i hand wash using a Multimeter in the USA area at PlumbersForums.net
This is a Triton hand wash, T30i .
Can I check whether the Element is working (or broken) using a Multimeter?
I attach a photo of the 'Can and Element assembly' unit.
You could check for continuity, if there is none then its faulty
You could also check the resistance / ohms but you would need to know the resistance of the element from the manufacturers instructions
Reply to How to check heating elements in Triton T30i hand wash using a Multimeter in the USA area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
PSxxxxxx
