Discuss How to clear partially blocked (not frozen) condensate pipe from top (boiler) end? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
Littleoldme
Boiler engineer said knocking noise and vibration was due to blocked condensate pipe due to boiler not being cleaned out regularly, cleaned it out but said he couldn't fix anything which was not inside the boiler. Company still charged me flat £240 fee for the privilege! Now skint. Second company's plumber said condensate pipe is partially blocked, he managed to clear it a bit, and I should try to blast it with an aerosol of some type, which he didn't have on him at the time. Where can I get one of the aerosols he was talikg about (in the UK?), what are they called, and what sort of gadget do I need to connect the aerosol to the white overflow pipe when I've unscrewed the condensate trap off the bottom of the boiler? Should I try buying a new condensate trap from the boiler manufacturer to see if that could be the problem, before I start trying to blast the pipe? I can't use a wet-and-dry vacuum to suck gunk from the bottom end because the condensate pipe is glued into the sink drain pipe with no unscrewable parts. Once the condensate pipe leaves the trap under the boiler, it disappears into the wall (through ceramic tiles) at 90 degrees, then presumably snakes down the inside of the wall with at least one or two further bends, before coming in through the back of the cupboard under the sink and going through 2 more 90 degree bends in an inaccessible place with a nearly horizontal final run to the sink waste pipe. There's not enough pipe for me to be able to cut and replace with unscrewable fittings down there, so I daren't try to tackle it from the bottom end. On the evidence of the second chap (who said the installation configuration was bound to cause problems) I called the builder's contractors in, but their man said there was enough drop in the condensate pipe from start to finish that all the 90 degree bends wouldn't matter, and refused to do anything to help. Any suggestions welcomed please...
Re: How to clear partially blocked (not frozen) condensate pipe from top (boiler) end
you cnnot tart taking the boiler apart unless your gas safe
They are called a gallow gun, they are availiable from PTS.
Is your boiler a Baxi 133? or 100? by any chance?
I think that tescos do a arosol type thing which has a domed rubber top which you place against plug holes then blast, that might work.
It's an ICOS HE15
Hi and many thanks. I haven't found the aerosol on Tesco's website yet, maybe I'm using the wrong search terms, but I will keep looking.
[DLMURL]http://www.diversitech.com/literature%5CLIT-FLY-GG.pdf[/DLMURL]
Wouldnt fancy using this tool, most condense pipes I come across fall apart or leak just knocking them.
Reply to How to clear partially blocked (not frozen) condensate pipe from top (boiler) end? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone I hope you can help. We were getting some work done and our builder attached the boiler condensate pipe to the sink waste pipe. This...
Sonya K
[ASIDE: I did wonder if this was the best forum for this but figured as it was a boiler related issue that the gas engineers would be dealing...
Hi guys. A couple of things. 1 am I better fabricating bends in 14 mm copper for my ch or are 90 degree elbows fine, ref flow, friction ect. 2...
Hi I need some advice as this has been ongoing since august and nobody can find a problem but meantime water is damaging my walls. The lady...
