Discuss How To Join Pipe Thread (garden hose) To Compression (sink) ? in the USA area at PlumbersForums.net
Deleted member 125263
I have a cold water sink in a shed a long way from the house. We just want to run a garden hose over to it and feed the tap from it.
The tap of course has a flexible hose underneath with a compression thread fitting I guess.
What sort of fitting or adapter do I look for so's I can plug my garden hose into it and feed it from there?
I can't locate one after searching pages and pages of fittings on hardware store sites.
Just to be clear - because I've googled and got many hits and they're all the wrong way round - I want the garden hose water going IN to the tap from underneath. I'm not trying to get water OUT from the tap to a hose.
The flex will fit into that as it has a reducer from 3/4 to 1/2 the tap flex is 15mm compression so remove the nut and olive and put the adapter on the thread and screw on
Reply to How To Join Pipe Thread (garden hose) To Compression (sink) ? in the USA area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
