Discuss How to remove leaking thermostat shower in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Nope not sure which one to buy, assuming i can get the cartridge outProbably new cartridge required, if you get it out, are you sure which one to buy?
Regardless of whether you can get the cartridge out, you need to obtain the correct one, eg manufacture specific, generally. If you can’t, then it’s likely to be new shower time. Post a photo of the temperature knob side on please.Nope not sure which one to buy, assuming i can get the cartridge out
Hi ChrisRegardless of whether you can get the cartridge out, you need to obtain the correct one, eg manufacture specific, generally. If you can’t, then it’s likely to be new shower time. Post a photo of the temperature knob side on please.
Have attached a couple of piccies. How do you remove the cartridge?Hi Chris
Looks like the cross head comes off, but doesn’t appear to be a removable cover, so likely another gun screw, once that’s off m then the rest should be easy enough.Have attached a couple of piccies. How do you remove the cartridge?
Reply to How to remove leaking thermostat shower in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
