Discuss How to remove stuck washer cartridge from mixer tap in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, I can’t get one cartridge to budge when trying to replace in a mixer tap. The hot side cartridge was tight but removed with wrench comfortably, but cold side is so tight Ive burred the nut on the cartridge. Any advice on how else to remove the cartridge without damaging the mixer tap is greatly appreciated.
What wrench are you using ?
mole grips
There’s your issue needs to be a decent spanner / adjustable to pump grips
There put in with a socket and wizzy gun
The hot water east due to the heat of the hot water loosing it up
You could a pair of 12” or 16” stilson
For future reference, you’re best off with a ring spanner or a socket as they grip all the way around the nut .
Now it’s mullered you are best off with a self tightening wrench which will grip well, but will usually cause a bit of damage. A great version of this is the good old stilsons - just go as big as you need….give up at 48” and just buy a new tap.
Reply to How to remove stuck washer cartridge from mixer tap in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have a plumber coming tomorrow to change a cartridge on a badly dripping tap on my bathroom mixer unit. There is no separate isolating valve for...
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
