Discuss How to remove 'top' of tap? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I need to fix a dripping tap - I thought by removing the screw at the top of the blue section the top of the tap would lift off... no such luck...
it is 'loose' but is stuck and won't lift up.
How do I get it off to then replace the washer?
Thanks in advance.
Reply to How to remove 'top' of tap? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
