Discuss How to replace a Baxi 105E microswitch? in the USA area at PlumbersForums.net
Hi
Looking to replace the Baxi 105E microswitch but Worried about getting the white connectors off without damaging the wiring.
has anyone done it and if so is there a trick to getting the connectors off?
Thank you for your response, I have now changed the microswitch which I was hoping would get rid of my intermittent 60 degree error (low pressure or pump fault) pressure is at 1.5 bar and I can hear the pump. Basically I get hot water fine and then at some point after, the error 60 comes on, I have also changed the diaphragm and greased the push rod..not sure what is left to try
They are just covered spade connectors so just either grab and wiggle them or use a flat screwdriver to lever them up
Pull off by hand or pliers. With power off.
You need to rebuild the whole diverter valve
As I guess you’ve replaced the front diaphragm washer
You are correct, I replaced the diaphragm which did have a rip, when you say build the diverter, I assume you mean only on the DHW, as not having any symptoms on the CH. Do you mean replacing the spring, mushroom and pushrod as in the attached link to the service kit: Baxi combi 80e & 105e DHW Hot Water Diaphragm, Repair Kit with plate 5111137 7824400586123 | eBay - https://www.ebay.co.uk/itm/Baxi-combi-80e-105e-DHW-Hot-Water-Diaphragm-Repair-Kit-with-plate-5111137-/273291486363?_trksid=p2349624.m46890.l49286
The pump proving switch isn’t on the hot water diaphragm it’s the one behind that one
what’s the fault other than the code
watch the rear microswitch when the fault happens
After every 4th or 5 th time the hot water has been run, at some point, the fault light comes on. I don’t believe it is whilst the hot water is running or straight after it has run but at some point after. If you leave it with the 60 light flashing, eventually it will go off. Thinking the pushrod might have been slow to retract but have watched it and it seems ok, did clean and grease it.
The front diaphragm doesn’t control the pump the rear one does
That’s the pump proving one so providing your info is correct should fix your problem or it’s a weak pump
Sorry, I have one last quick question, when I replaced the DHW diaphragm, I just turned the Mains off and ran the hot tap until there was no more water. Am I able to do the same when replacing the CH diaphragm or do I have to drain the boiler?
Have to drain the heating system if your upstairs and above the radiators only need to drain the boiler but if your downstairs need to drain everything above the boiler
Thanks for all your help, so just so I am clear if you are replacing the DHW diaphragm you just need to turn mains off and run tap but if you are changing the CH diaphragm you have to drain the boiler? I will also get some fernox inhibitor when I do drain it down
Correct and anything above the boiler
Reply to How to replace a Baxi 105E microswitch? in the USA area at PlumbersForums.net
I have a very strange issue with my BAXI 105e DHW. if i turn on the hot tap the pump starts and demand for DHW is shown, after a some seconds it...
Hi all, Quick question. I have a baxi 105e instant that has a Diverter valve issue. The bypass is allowing hot water around the bypass pipe and...
Hi all,new to the forum and hoping to get some guidance through the boiler minefield . We moved into a 70s bungalow last Feb,its got a Greensted...
Hi all. After some advice before I get some quotes. I have a 19 year old baxi 105e instant that needs replaced for something more efficient. I’m...
2K
Hi folks, hoping someone can help with a problem that's been perplexing me since just before Christmas..... I have a wet underfloor heating system...
1K
