Discuss How to stop Back-flow into overflow ? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
My plumber did not install an overflow when my water softener was fitted, something I found out when it failed and flooded the floor !
I have installed a 12mm overflow hose into a compression T joint, however I'm getting back flow, from both the washing machine, and probably the water-softener drain too. I have attached a diagram, What's the best way to stop this ? or an alternate way way to plumb the overflow into waste water ?
Mechanical trap between Softner and washing machine.
You’ve likely got a partial blockage causing the black flow. Need to unblock it
I think the (low volume, partial) backflow is caused by (a) the low height differences between the s bends and (b) the low drop of the drain pipe. Neither of which are easy to change. I will also check for blockage,
What sort of mechanical trap ?
Do I have any other options ?
If the washing machine backflow is capable of rising 200mm up the stand pipe to the softener, I highly suspect a partial blockage.
A trap like this.
Reply to How to stop Back-flow into overflow ? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the sink, dishwasher, washing machine etc. When I pour the concrete there won't be any chance to dig it up anymore. From my own research I get the...
