Discuss How to switch comfort mode off on a Valliant ecoTec pro28 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
michael98
How to switch comfort mode off on a Valliant ecoTec pro28.
only found instructions on how to do it on different models and not this one.
Please see attachment. I have the following buttons: turn off flame, Info, - (minus), and +(plus).
Thanks you.
Turn hot water temp right down to min until light goes off then back to set temp.
To turn on again go right to max and then set desired temp
Reply to How to switch comfort mode off on a Valliant ecoTec pro28 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello everyone, I'm facing an issue with my Vaillant EcoTec 832 boiler and would greatly appreciate your expert advice. The Problem: Heating...
Hi, Have a Valliant Ecotec Plus 637 system boiler that is showing no error codes and S.0 (no demand for heat), but it is not heating. Have...
1K
Hello, I hope someone can give some advice with this problem. I have a Vaillant ecoTec plus 418 with Drayton MA1 mid-position actuator, Drayton...
I am generally a decent handyman, can usually make 2+2=4 and take care of most things to avoid troubling experts with just the basics, but know...
The problem is, my ideal boiler logic heat h15 keeps on burning (igniting flame icon on) all the time, all day long, regardless of the programmed...
4K
Deleted member 120897
