Discuss How to tap off a 15mm compression to 1/2? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
While I am a trained engineer I appear blind when it comes to plumbing fittings. I want to tee off the 15mm compression (copper pipe to flex hose) to loo so as to supply a cold water bidet. The bidet is suppplied via a 1/2 connection. So appears simple, a tee but cannot find - any suggestions would be appreciated.
Is it wras approved ?
Reply to How to tap off a 15mm compression to 1/2? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
