Currently reading:
How to top up Vaillant ecotech pro 28 R2 boiler
Discuss How to top up Vaillant ecotech pro 28 R2 boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
eug_1
Hi All
This is my first post.
Please see attached to this post some pics of the set-up of my boiler.
The pressure has dropped to 0.8bar and I was trying to top up the system by opening the two taps connected to the silver flexi pipe but that didnt work.
I am not sure what I am doing wrong.
Please help.
Eug
Have you tried opening the stop taps either side of the flexi taps as well ?
Hi Shaun
Yep...I tried opening both taps and the little stop valve in the middle and it didnt work.
so just to confirm you have opened the 2 black lever valves and also the 2 brass stop taps
if yes you will need a heating eng out to have a look, sorry to say
Hi Shaun
Only one black lever is a stop valve,the other seems to be a check valve.So I opened bot taps and the one black lever stop valve.
I was hoping not to get an ENG out but I can see your point.
Thanks....
you need to open both black taps the check valve bit is there to stop water from the heating going back into the mains
There are two black stop valves. One is a small one with the handle only sticking out one side of the spindle (on the horizontal pipe), the other is a butterfly type handle that sticks out both sides of the spindle (up on the wall).
Thank you all for your information,much appreciated
I have now topped up the system.I dont know why i thought the butterfly valve was just a non return valve....
Reply to How to top up Vaillant ecotech pro 28 R2 boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
