Discuss How to wire Nest gen 3 into Ideal Vogue Gen2 combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone help with wiring diagram and connections on boiler that must be connected\disconnected or linked.
need to be gas safe reg to do the wiring inside the boiler
Not a clue if I'm honest. But get in wrong it could be very expensive, you could fry the board or set fire to the boiler.
Sometimes it's cheaper to pay someone if you don't know how.
I'm pretty sure they offer fitting for 100 quid. A customer asked me to wire one into a Viessman 200 that had weather comp and three zoned and after looking at the wiring even I wasn't sure so I just called the company and they sent someone who knew. Even gas engineers need support on electronics so just get a competent person in.
Reply to How to wire Nest gen 3 into Ideal Vogue Gen2 combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Fellow Engineers I've attached a wiring diagram I've just completed, I wanted to make sure I've got it correct. Looking to install 2 Nest...
Hey folks, I'm wondering if someone could possibly help, I'm looking for a possible part number b4 I call ideal in the morning, I fitted an...
Deleted member 120897
Hi all, I have just bought a google nest 3rd gen thermostat to be connected opentherm. I currently have the baxi ifos rather comp fitted. I was...
Hi guys, I have a set up with rads upstairs and UFH downstairs. I have installed the manifold for the UFH along with 2x Honeywell 2port values...
2K
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
