Discuss How to wire Nest gen 3 into Ideal Vogue Gen2 combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
need to be gas safe reg to do the wiring inside the boiler
Not a clue if I'm honest. But get in wrong it could be very expensive, you could fry the board or set fire to the boiler.
Sometimes it's cheaper to pay someone if you don't know how.
I'm pretty sure they offer fitting for 100 quid. A customer asked me to wire one into a Viessman 200 that had weather comp and three zoned and after looking at the wiring even I wasn't sure so I just called the company and they sent someone who knew. Even gas engineers need support on electronics so just get a competent person in.
Reply to How to wire Nest gen 3 into Ideal Vogue Gen2 combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
