Discuss How Yo Connect Water Supply To New Bath Taps in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi
I have a 22mm hot and cold water supply to new bath. The pipes finish with compression valves. I need a 500 mm tap connector hose to connect with half inch thread on the new bath tap. All the connectors at the main plumb merchants are 22mm x 3/4 inch. No one seems able to answer question.
Any advice much appreciated.
1. What sort of tap - 2 x singles, 1 x deck mixer, monobloc?
2. What shank(s) do / does the tap(s) have?
3. Picture of what you term compression valves and connection point(s) on tap would be useful.
Itā€™s not a bath tap if itā€™s 1/2
Hi I hope these pictures make the dilemma clear. The 22mm flexible hose 3/4 ā€œ does not connect to the half in taps. None of the plumbing suppliers I have tried can provide a flexible connector with the right fittings. The tap is by Flova.
The Technical Data Sheet clear BSP Imperial 1/2. And it clearly states itā€™s a bath tap. Iā€™m confused.
Many thanks
3/4 - 1/2 brass bush
Reply to How Yo Connect Water Supply To New Bath Taps in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
