Discuss How Yo Connect Water Supply To New Bath Taps in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi
I have a 22mm hot and cold water supply to new bath. The pipes finish with compression valves. I need a 500 mm tap connector hose to connect with half inch thread on the new bath tap. All the connectors at the main plumb merchants are 22mm x 3/4 inch. No one seems able to answer question.
Any advice much appreciated.
1. What sort of tap - 2 x singles, 1 x deck mixer, monobloc?
2. What shank(s) do / does the tap(s) have?
3. Picture of what you term compression valves and connection point(s) on tap would be useful.
It’s not a bath tap if it’s 1/2
Hi I hope these pictures make the dilemma clear. The 22mm flexible hose 3/4 “ does not connect to the half in taps. None of the plumbing suppliers I have tried can provide a flexible connector with the right fittings. The tap is by Flova.
The Technical Data Sheet clear BSP Imperial 1/2. And it clearly states it’s a bath tap. I’m confused.
Many thanks
3/4 - 1/2 brass bush
Reply to How Yo Connect Water Supply To New Bath Taps in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
