Discuss Hudson Reed 4 hole bath taps?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Ok so I have bought these taps for my new bathroom and when I went to fit them earlier they came with no instructions and didn’t come with the fittings to connect the taps to the spout, if you can see the pic I just want 125mm between each bath hole,
I’m stumped because I’m not sure how far apart I am to drill for the holes in the bath, there 1/2” male connectors so I can put tap washers on them and 15mm pipe between but that would space the taps to far apart, any suggestions?
I believe that you have the flexi pipes in the wrong place. They should connect the side connection on the spout to the side connection on the taps.
Turn the connections on the taps away from the centre and use the supplied flexi to join.
Oh right I see, but I thought that may be to close to put a flexi and it may split as it’s looped so much? Shall I turn the taps so there facing the other way then or just turn them 90 degrees so there facing the back wall?
As stated. That is what chalked was talking about. Not the best design though to be honest. But you have to work with what you have got. Don’t you.
Them flexis would go straight in the bin and id pipe in between the taps and spout in copper, female irons and copper!
Reply to Hudson Reed 4 hole bath taps?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes a squeak noise as I turn it on or off, left tap is 100% perfect and noiseless. This grohe tap is like one unit, so no screw notch or way I can remove...
