Discuss HW CH Mixed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jj1251199
Hello there hoping you could help.
I just recently had to replace my Vokera Mynute 20 3 with an Ariston E-System 24 boiler after the recent cold weather.
The boiler itself seems to be working fine, but it is the controls I am worried about from the programmer. The momo valves don’t seem to operate
It used to be that you had the hot water and CH operating separately.
Now when I turn on the CH I get hot water from the immersion tank. When I turn on the hot water it also heats up the radiators.
The valves seem to be in the open position all the time. I took the actuator off the hot water valve and manually closed it so the water cannot flow into the hot water tank. This is a quick fix as I don’t not use much HW, mainly the CH.
When you turn either the HW or CH on at the programmer, you do hear a little click from the valve which I take to be the micro switch, but I would have thought this switch would have been activated by the valve rotating. I have not seen the valves rotate when turning on at the programmer.
I’m guessing, not from any experience, that there is something wrong with the motor in the valves as they don’t turn and everything else seems to be OK. Is it possible that the electrican has wired the valves in a way that only the motors do not work. They worked fine before the new boiler was fitted.
Can anyone help
As said ,if you have paid to have something done and it is not done correctly,get them back to sort out the problem,you could just make sure the motorised valves have not been left on manual,with the manual nlevers on the side,as may have been left like this when commisioning but do not mess with to much or they may blame you for problems !!
sounds like a wiring fault is there power on the brown lead of each valve when respective channel is selected at clock with stats on
i checked the power with a phase tester. there is power on each valve. wasnt expecting that. again i listened to the valve when turning the programmer on and off. Just a single click from the acutator on each press of the programmer button
Is there anything else I can check. The reason why I am looking to get some onformation is so I can go back to the lectrician. He is adament at the minute that he has wired it up correctly but it isnt the same as beofre the boiler was fitted
Reply to HW CH Mixed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, Hope somebody can help :) I have a vented HW system with a pressurised Ch system but got bit of a annoying issue, when the hot water...
Do people with this type of mixed flow temperature control have any problems with achieving the required manifold flow temperature? The one below...
Hi all. My hot water feed for my shower is on the left and the cold is on the right. My understanding is that this is correct and this is also...
Hello, my HW is taking longer than expected to heat up and it's getting worse. I can go 10-40 degs after 1.5 hours of only heating HW, whereas I...
Hello. I've just replaced our old Potterton EP2 CH controller with a Drayton Wiser HubR (& peripherals). The old backing plate wasn't...
