E
EngineerDave101
I have recently moved in to a house with oil central heating.
There is an MA1 mid-position valve, HTS3 cylinder thermostat and a Lifestyle LP522 programmer.
The problem is that the water in the cylinder gets too hot.
The cylinder thermostat is working correctly - moving the valve to the CH position when the tank temperature is satisfied.
I would have expected the pipework from the valve to the tank to reduce in temperature somewhat, however it continues to be exceedingly hot - the same as the CH pipework as far as I can tell.
The tank thermostat is set at 60 degrees and the boiler thermostat at about 75 degrees.
I note that the lever on the side of the valve indicating its position is not fully home at either the HW or CH positions but assume this is normal.
Is there a problem with the valve, i.e. is water bypassing the closed HW port and continuing to heat up the tank, or is something else going on?
PS I am a new member and very please to be on board.
