Discuss hw cylinders piped up in hep20 is this allowed ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
leeking
never seen this before or heard of it . I dont think this can be right . what say you ! cheers
when i was working on sites we piped up all our cylinders in equator pipe.
cheers, I have always done them in copper , I have been asked to benchmark 28 so was wondering..
looks s.h.i.t
i would work on the same princaple with boilers,ie min 1 metre of copper from boiler,
so i would say min 1 metre from unoins
Cheers wn , same here , would you put your name to ones done in hep ?
I would not sign off anyones HEp2o , how do you know support sleeves are in ? Has it been pressure tested as per Hepworths proceedure ?
good point taddy, and there is no way they will have been tested to hep's test. this firm gave me an independant report where they stated use of hep was not advised though permissable. My advice was to replace all pipe work but firm are obviously not wanting that cost and are leaning on the report. p.s every one had a gate valve on hot feed :eek::eek::eek::eek::eek:
In your other post you say that these are Unvented Cylinders ! These should have been installed by a registered installer. Temp pressure relief has to be in metal pipe !!! I would ask Hepworth or Cylinder manufacturer before going any futher , but I have warning bells ringing , plastic pipe and elevated temps and pressures !
Indeed, very loud alarm bells ! Phoned santon technical today & they recommend 1m of copper from cylinder. End of for story ! Thanks to all for input. :)
Reply to hw cylinders piped up in hep20 is this allowed ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
