Discuss Hydroflow 38 units with damaged boxes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Olly
Just wondering if many of you have had any experience with the hydroflow 38 descaling units?
1. Do they work?
2. Why are there so many selling on ebay but all with damaged boxes? Have they fallen off back of a lorry???
Cheers,
Olly
Reply to Hydroflow 38 units with damaged boxes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
