Discuss I get myself in a muddle sometimes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
king of pipes
Subscribed
Another kitchen upgrade started FFS I get myself in a muddle o_O.kop
Yep 2 of us bud I am doing the prep work and then work in together next week cleaned all the crap off now insulation board going on external wall :):)
Looks good, did you remove the plasterboard or install it over the top ?
A day and a half should see me done here been alot of stuff done some of these smaller jobs take just as long have a good weekend chaps .kop
Looking good kop what’s the splash a panel or a worktop ?
9mm panel Shaun just the top and bottom of the boiler to sort out , and the kickboards few other little jobs then I will be done , used multi panel flooring a first for me 5mm thick click vinyl piece of cake to fit put underlay down first and just clicks in place . Cheers Wayne
Looks good quite like the panelling :D
Reply to I get myself in a muddle sometimes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
