Discuss I have a F1 fault code on my ideal boiler, the pressure is fine? in the Central Heating Forum area at PlumbersForums.net
Pressure is ok but increased to see if boiler would click into action but didn’t, have reduced back, needle is moving on pressure gauge, have tried reset but still nothing, any ideas before I call someone out? Thanks
Yep easy enough fault for a gas safe engy common fault internal part is blocked
Reply to I have a F1 fault code on my ideal boiler, the pressure is fine? in the Central Heating Forum area at PlumbersForums.net
After researching as much as I can to sort this problem, I keep reading that if your Ideal boiler has an F1 code and the pressure is low, it needs...
Got up on Wednesday morning no hot water, (only cold water coming out of hot tap). Checked boiler, it had zero pressure and F1 fault showing. So I...
1K
Morco feb 24ed3 has a f1 fault code. The burner reading is fine. The fault is intermittent, sometimes the boiler won't ignite on either hot water...
Hi All Bit of an urgent one being that time of year and can't get a plumber out until after xmas even on an emergency callout I have just...
Hi I have a Vokera 15 vhe boiler and all has been running well for the last 6 months since moving in up until a few weeks a go. Boiler throws up...
1K
