Discuss I think I've got low flow rates to bath & basin in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
johnst
I've just had a new bathroom fitted.
Before this the pressure & flow from bath & basin taps were good.
Now it is much reduced.
The new taps fitted are Crosswater Voyager which are said to be suitable for LP systems.
Any suggestions as to what might be causing the problem?
Is there any chance that the taps are rated at 0.5 bar minimum working pressure.
0.5 is classed as low pressure and typically 0.2 is the available head for a tank fed system feeding a bathroom.
Ballafix valves reducing flow rate?
flow restricter inserts?
Isolation valves were changed from the type with a red handwheel to lever operated.
Would this cause a loss of flow?
Gate valves (redhandled) are pretty much full bore when opened fully but most lever valves are a lot less when opened so yes you would lose flow through those.
Reply to I think I've got low flow rates to bath & basin in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Could I ask for some help with a water flow rate problem. I have good mains water pressure on the ground floor. There is no tank in the loft...
1K
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the...
Essaboy
E
I'm having a nightmare trying to find matt black wall or deck mounted bath mixer taps with 3/4 fitting that work on 0.2 bar. From tank to tap, I...
I live in an apartment with a cold water tank. The cold water tank feeds the cold water tap in the sink and the bath. Recently, I refurbished my...
