Discuss Icos he18 l and f code in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Christopher Powell
Hi all. Hope you can help.
Been to look at an ideal icos he 18 l & f code. Done everything from the flow chart and changed the flame detection probe. Contacted ideal and they're advice was to boil the kettle a few times and flush the heat exchanger to clear the aluminium oxide build up.
Ive also cleared the trap and cleaned out the sump at tue bottom of the heat exchanger. The water i poured in ran out freely with no restrictions.
Im stumped. Could it be a faulty gas valve as it runs fine for 5 or 10 minutes then cuts out. Leave for a minute and reset and it'll come back on.
If you were registered, you’d have the blue badge.. but you don’t get the free parking
You rang :D
Fave on them is the flame rec lead , they crack and loose continuity, if the probe is brand new , change the lead , I would also , if the customer is ok with it change the spark gen and the ignition electrode , but you could just change the lead and try it .
That normally fixes them . Good luck
The lead from the flame detector? Could it be that simple. Ive tested it with the multimeter and registered voltage when it fired up. Obviously when its running its losing something. Seems strange that after a minute or 2 being shut down it'll start back up again. Ill definitely try it though. Cheers
Very cheap , defo worth trying , but I agree you wouldn’t expect it to break down in a few mins , but honestly I have changed loads .
Trying to figure this out.
It would seem that if one is not gas safe registered gas boiler repair
repair advice will not be given on open forum, but once proved to be registered then it is okay to give gas boiler repair advice on open forum.
Will be moved once he has his badge don't worrie will mop up
Done
You have not broken any rules.
Glad you got the answer you need.
An extra 10000 'experts' out there now able to give advice
on fixing icos's.
You are 100% correct it shouldn’t have been on an open forum , I was more interested the OP was gas safe. As for the 10000 new icos experts they now have an idea how to fix one of the many icos fault codes , half the fault codes dont relate to the specific fault anyway , and I have heard theres only 30 left lol .
on fixing icos's.
Give over 10000 new experts guess you've never been on u tube have a look at the icos fixing vids
Doubt there 10k left in the uk
Bugger !! Get ready potential nightmare now.
When it cuts out , does it cut out “dead” no fan etc , or do you get the flashing blue light , then goes to fault
Bridgend area South Wales .
There's not really alot in there to go wrong really is there. Hope a new valve sorts it.
Ideal helpline happily dishing out info without checking i was gas safe too
Reason I asked is I have a working / secondhand valve , you could have cadged it if you were closer.
Let us know how you get on .
A lot of the wiring on the Icos harness / loom is starting to split and break but to be fair , they are old boilers now .
Reply to Icos he18 l and f code in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Icos HE24 showing L-F code. If i reset it goes into start up mode. Can hear burner fire but accompanied by a bubbling/gurgling then goes into L-F .
Deleted member 120897
Folks Me again I am at my wits end. I want to replace the boiler but I am on my backside and cannot afford to. I have been getting an...
Hi Fitted a new out the box’s boiler today. It worked for 30 minutes. Then stoped and went to fault codes 2965 B Flow temperature too high ▶...
N
Hi All I know I know ... another HE24 LF code problem. Fix is replace boiler ;-) My problem is slightly different to other posts I've been...
3K
Mikesin
M
Hi All I tried posting this already and lost post so here goes again. I'll start from the beginning so please bare with me. Few Months ago I...
2K
