Discuss Ideal Concord WRS 255A pipe connections? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
need to do a good power flush on system and fit a ch filter , if they dont want it then list on benchmark customer refuse to have one or anything similar
replaced same boiler few months back. follow pipes from cylinder for your hw/cold run and use your boiler flow/return for your heating run. mark your pipes before you cut them :D and its gonna be some scrap as well after you remove all that excess pipework in the cupboard.
Reply to Ideal Concord WRS 255A pipe connections? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
Sonya K
