Discuss Ideal independent C24 hot water issues. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have Ideal independent C24 for about 5 years, eralier on this year I stared to get not too warm water, I cleaner plate heat exchanger and problem stopped, however I had no regulation on the mixer in the tap, instantly when I wanted to mix the hot with cold water boiler burner would cut off. I changed diverter valve and problem disapeared for few days.
No it looks like the boiler only fires up from bath tap, all other taps cant triger the burner, and even when I run the water from bath mixer I can not mix hot and cold water as burner cuts off again.
Looking at the manaul for Ideal, troubleshouting takes me to faulty PCB.
anyone has any ideas what can case the issues?
Are you gas safe registered if you arnt naughty naughty you've just broken the law and your home insurance is out the window
Get an approved gas safe engy in
That'll be the usual things which are common on these!
Reply to Ideal independent C24 hot water issues. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
