Discuss Ideal Independent C24 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
kb76
Hi, been to one of these this morning which looks no different to a Logic badged up different. Upon power up on spur with boiler selector switch in off position it's still going through its first stages of demand bar ignition then get L followed 2. Manual points to board or gas valve, getting correct resistance across furthest pins on valve. Anyone else had this on one of these?
ignition electrode, spark generator and lead or a bad earth
Thanks quality. What's causing it to come to life when selector is in the off position?
Update. Found the isolator spindle had sheared off on PCB. Although the knob was springing back after resetting it wasn't actually resetting the boiler hence the last fault code L2 still being displayed, tenant has token meter and must have run out of gas...arrhh! New knob and running again...
Reply to Ideal Independent C24 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello friends - I really struggle to understand my heating and hot water system I posted my question on Diynot but it ended up being five pages...
Hi, Non-professional / knowledgeable person here. I'm a Brit in Romania who volunteers for a charity building an old peoples home for needy old...
In our Village Hall we have a Ideal Concord CXS/SD40/H central heating boiler. This was installed new when we had an extension built and the...
1K
Hi, As per the thread title, I have an Ideal Logic Combi 30 and I am having a problem with the pump, which keeps activating without any DHW/DCH...
1K
HI folks, this post is a follow up to my post relating to my single pipe heating system. In summary, I have a house built in 1980 (I bought it 2...
