Discuss Ideal Isar HE 35 cutting out in the Central Heating Forum area at PlumbersForums.net
Sandeep89
Hi Guys,
Customer has a Ideal Isar HE35 when the boiler fires up for ether hot water or heating, there is knocking noise which seem to he coming from inside the flue manifold.
Boiler fires up, knocking noises can be heard from some seconds, after this the boiler cuts out and water squirts out of the AAV. The boiler then re-fires itself after a little while and the same thing happens again.
Any ideas what could be causing this.
I also noticed that the pressure gauge is rapidly moving up and down whilst the boiler is working, is it meant to be doing this
Reply to Ideal Isar HE 35 cutting out in the Central Heating Forum area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was...
Sonya K
