Discuss ideal isarrrgggghhhh he30 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
aligorgon
Was called to one today, running the hot water tap made the heating come on and no hot water out of tap...
so drained, disconnected all those stupid blocks and got to the diverter then replaced the cartridge (the old one was cracked in a few places) removed the plate HE and give that a flush through and then reassembled everything.
turned it on and boiler was calling for hot water and i got the d showing on the display. but burner wasn't igniting so i assumed i had put one of the connectors in the wrong place and swapped it with another (it was 30mins past finishing time by this stage and i know i should've checked the wiring diagram 1st) ... turned the boiler back on and POP from that dumb orange box
awesome... i love these things :-( so its a return visit in the morning
any ideas what could have been holding the burner off when running the hot tap ? the d was up on the display
not the dreaded orange pcb box that you can accidentally put the fan lead into another identically shaped connection and blow up the pcb...i hate those boilers..
ive done that and was 160 odd pound down, wounded. now its all about label label label.
I love the front rocker switch when the spade connector covers are fecked and when u energise pop. Arcs onto case!
No idea why the PCB decided to die on you but usual issue after draining these down is that the auto vent is clogged so any air in the hex isn't released... Because they have to pre-heat before opening the diverter to the heating the hex is full of air and never released .. Pump has nothing to 'pump'! .. that'll usually trip the boiler to o-heat/dry fire fault or the "- -" display on the user control!
ahh well more fun today with it..
picked up the orange box and swapped it out checked and double checked all the connectors were in the correct place.. in fact one of our sparks came over to check too...
turned it on and got the fan fault code so did the checks in the manual and picked up and new fan, fitted it, and connected it up. ... turned the boiler on and pop from the new pcb...
ffs....
opened the orange box and a nice black circle in the middle...
spoke to technical and they advised new wiring loom ...
its a HA contract so a new boilers getting fitted tomorrow ... fustrated isn't the word...
We always change the harness if you change the fan. Think the old one runs down back of hex and is un insulated. New ones have a thick black insulation round them.
We found out after it turns out another engineer burnt out 3 PCB's and replaced the fan twice..........
Boss wasn't happy! Haha.
A little tip..before pulling plugs on pcb.s snap it with your smartphone...
A little tip, if boiler is an Ideal Isar, tell them a new boiler is needed or make some lame excuse and walk away
Am I thinking of a different boiler? Only two plugs that are interchangeable ?
Every time I see an Isar I always suck in through my teeth in front of the punter, this combined with a wee shake of my head usually conveys the gravity of the situation
You are time served then. An ametur just utters in the style of Danny fire , arrrr eggs n shells luv gonna need a new one. Betta wring govnor'
I hate bumin isars i have one to service next week that hasn't been done for age's apparently, the thought just sends shivers down my spine. The customers have only just bought the house I told them that the boiler was pants before they bought the house, but as usual they though I was just trying to sell them a new boiler ,I think they are going to find out the hard way.
If this has happened where the fan has blown the board, I've had this before. What had happened is the insulation pads had fallen down, the back had melted out the heat ex and then melted the fan harness, creating a short dc circuit. Boiler was totally wrecked. Actually a potential fire hazard.
Reply to ideal isarrrgggghhhh he30 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an ideal Isar He30 ( yes I know they are crap!) the boiler works but the contol panel asppears to be dead, the DHW and CH temperature...
Hi There was no shut off valve on the tank feed to the hot water cylinder, and I needed to move a couple of hot water pipes, so I shut off the...
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
Hello friends - I really struggle to understand my heating and hot water system I posted my question on Diynot but it ended up being five pages...
