Discuss Ideal Logic Weather Compensation Kit in the Central Heating Forum area at PlumbersForums.net
J
Jack’s
Hi Anyone know difference between Ideal Logic Combi Weather Compensation Kit(round box) ad new one 216199 model?Need this for my new Ideal Logic + boiler
According to Ideal Website Weather Compensation Manual Download
(unable to post link for some reason)
idealheating.com/products/weather-compensation-kit
idealheating.com/uploads/documents/Weather_Compensation_Kit_User_Guide.pdf
This kit is suitable only for the domestic gas boilers listed below:
Note
1. A timer should be fitted to the system so that CH will be switched off when appropriate
2. The Connector (Frame 1, item C). is prefitted to certain boilers. Boilers that don't have this fitted are marked with an * on page 2.
  • COMBI BOILERS
  • *Logic Combi
  • *Logic Combi C
  • IE Logic Combi ES
  • Logic Code Combi ES
  • Logic+ Combi
  • *Independent Com
  • *Independent+ Com
  • *i-mini C Vogue
  • Combi C GEN2 Vogue
  • Combi C IE GE
  • Logic Max Combi C
  • Vogue Max Com
  • HEAT BOILERS
  • Logic Heat
  • Logic Heat H
  • Logic+ Heat
  • Logic Max Heat
  • SYSTEM BOILE
  • Logic System
  • Logic System S
  • Logic+ System
  • Vogue System S GEN2
  • Vogue System S IE GEN2
  • Logic Max System S Vogue Max System
Reply to Ideal Logic Weather Compensation Kit in the Central Heating Forum area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
