Discuss Ideal Logic Weather Compensation Kit in the Central Heating Forum area at PlumbersForums.net
J
Jack’s
Hi Anyone know difference between Ideal Logic Combi Weather Compensation Kit(round box) ad new one 216199 model?Need this for my new Ideal Logic + boiler
According to Ideal Website Weather Compensation Manual Download
(unable to post link for some reason)
idealheating.com/products/weather-compensation-kit
idealheating.com/uploads/documents/Weather_Compensation_Kit_User_Guide.pdf
This kit is suitable only for the domestic gas boilers listed below:
Note
1. A timer should be fitted to the system so that CH will be switched off when appropriate
2. The Connector (Frame 1, item C). is prefitted to certain boilers. Boilers that don't have this fitted are marked with an * on page 2.
  • COMBI BOILERS
  • *Logic Combi
  • *Logic Combi C
  • IE Logic Combi ES
  • Logic Code Combi ES
  • Logic+ Combi
  • *Independent Com
  • *Independent+ Com
  • *i-mini C Vogue
  • Combi C GEN2 Vogue
  • Combi C IE GE
  • Logic Max Combi C
  • Vogue Max Com
  • HEAT BOILERS
  • Logic Heat
  • Logic Heat H
  • Logic+ Heat
  • Logic Max Heat
  • SYSTEM BOILE
  • Logic System
  • Logic System S
  • Logic+ System
  • Vogue System S GEN2
  • Vogue System S IE GEN2
  • Logic Max System S Vogue Max System
Reply to Ideal Logic Weather Compensation Kit in the Central Heating Forum area at PlumbersForums.net
Does anyone know of a weather compensation unit that can be fitted to a cylinder? I have an Ideal Logic Max H24 which heats a thermal store. The...
C
I’ve had an Ideal Vogue 32max/gen2 system boiler to a Megaflo fitted a week and running it at Flow temp 73 degrees to getting a return temp of...
Has anyone else come across this situation? I keep detecting products of combustion inside the casing of Ideal Logic boilers. I've replaced every...
Got up on Wednesday morning no hot water, (only cold water coming out of hot tap). Checked boiler, it had zero pressure and F1 fault showing. So I...
J
Hi I have 8 months old ideal logic + combi boiler. When I checking "Super Efficiency" reading on the LCD display is 51% only. How to incest...
2K
