Discuss IDEAL - Vertical FLUE in the Central Heating Forum area at PlumbersForums.net
I have a customer that wants me to fully strip down and service their boiler,
I have been round previously for other work
I did have a look at their boiler and flue.
The flue has caught my attention as there do not seem to be any "ports for flue analyser. it is a vertical flue.
i am newly qualified and am I missing the obvious here? I would AR this boiler
What boiler ?
No test point In the flue ?
Has it not got one of these just above the boiler?
Should be a black spigot right hand side top then
Reply to IDEAL - Vertical FLUE in the Central Heating Forum area at PlumbersForums.net
My installation has been classed as Dangerous 'Do not use' by my boiler manufacturer. I have an Ideal Logic 30kw Combi boiler mounted as high as can be on the kitchen wall. Flue exits out through the wall via an elbow but emerges above a flat roof. Unfortunately it's somewhat less than the...
1K
I am after an advice, please. We have a vertical radiator from Reina, Evie, that heats up only 2nd column fully, 1,3 and 4 are lukewarm. I borrowed a thermal camera and attached is the thermal image. System is balanced, there doesn't seem to be air coming out of the bleeding valve and was...
I just had a quote for a new boiler install as follows I dont undertand why a 15-60 boiler pump is needed and a 25-100 pump is needed as well I currently have an ideal mexico 2 heat only boiler - It has one DAB pump on the boiler return and a 2 port valve at the flow pipe to allow for heating...
Had our gas Baxi Combi inspected and serviced today, as it has been every year. Gas safety cert issued and says all okay, but engineer gave what I think was very... ambiguous... advice. 12yo boiler with the following readings on the analyser printout: O2% = 4.1 CO ppm = 192 CO2% = 9.5 Ratio =...
