Discuss Ideal vogue c32 in the USA area at PlumbersForums.net
just moved into a new house with the above boiler fitted about 3 months ago.
getting to grips with setting up all the timings etc.
One thing I have noticed is that on the display even with the ch off the ch radiator on the display flashes and says on. Am I missing something or is this a easy fix?.
have tried turning the dial to off and max and it still says on.
last pic is of the thermostat to show no heating on.
thanks
Something must be calling for heat or wired incorrectly
Is there another programmer for the other - rads or UFH?
I’ve got an app that can set the timings for ch and it’s got sensors apparently which I’ve turned off the floor ones but still got a demand for ch ??
You should have a timer for the radiators or the ufh depending on what system your WiFi one does
Reply to Ideal vogue c32 in the USA area at PlumbersForums.net
