Discuss Identify Unknown Pipe Fitting in the DIY Plumbing Forum area at PlumbersForums.net
Hoping that someone could please identify what this leaking fitting is, such that I can explain it to a plumber.
Not sure whether the groove on the top is a location where you can tighten these "fittings", or whether that is best left to a professional to deal with.
Many thanks for any help.
These are push-on vents. I hope it got fixed by now. Anyway, you can call an expert anytime if the leaking issue still exists.
Thanks for the info, much appreciated.
I have managed to tighten the fitting using some grips, which seems to have fixed the leak, however, I am intending to get the 6-12 of these I have upstairs replaced as I already have a brown stain on my kitchen ceiling after a recent concealed cistern leak.
Have tried to search the net to find out how these push-on vents actually work, but with little success but I will persevere!
Cheers.
6 -12 manual vents really? Seems excessive unless you have alot of dead legs or a problem with air ingress. Nothing to them really, unscrew the valve to release any trapped air or blead your system and they can quite easily removed with the right tool.
What has a leaky cistern got to do with it?
Reply to Identify Unknown Pipe Fitting in the DIY Plumbing Forum area at PlumbersForums.net
Sonya K
