Discuss illegal to open case unless gsr in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jonw
can someone show me where it is written in law that it is illegal for a homeowner to remove the case of their own boiler unless they are gsr? not touching any gas parts just looking for leak in cold water supply.
The reasoning behind it is that on many boilers the case forms part of the combustion seal.
As a consequence if you remove it you have no means to test to make sure it's been installed again properly
Thanks that is a proper useful answer.
I'm not sure from typed wording if that's sarcasm or not but that is the reason it's pretty cut and dry
No definitely not sarcasm. It was a really useful answer because now I understand why which is better than just knowing the rule. Many thanks.
I am a truth seeker and would never use sarcasm.
Riley, I dont suppose do you happen to know if that is the case for the greenstar 24/28i junior? No probs if not I'll ask my gas safety guy on his next visit.
Yes it is as there's no secondary case for the gas parts
Yes that is a nice picture. Obviously I know working with gas is dangerous. Which is why I asked the question which was to yield a discussion to figure out what constitutes 'gas works' as apposed to plumbing. Riley's answer superbly and succinctly cut straight to what I needed to know. Your picture is clever, even funny but not actually very helpful.
You're probably referring to your thread that I closed down.
As Riley said above, many cases form part of the combustion seal. We don't expect you to know which ones and, to be honest, we can't be bothered to wade through the hundreds of manufacturers instructions to answer each query.
So we take a wide and sweeping view on the matter. Same goes with pcbs as many of these need setting up after replacement.
At the end of the day we try to take a responsible position with regards to your safety which occasionally means telling you to stop and get someone in.
Normally people this happens to get snippy and either pm us or spam us resulting in a ban.
However, you've asked a reasonable question and accepted the answer. Thank you for that.
Nicely said croppie, I understand you get some right shirty nutters on forums :)
I'm booking a guy to come and do it next week. And now I know more than I did this morning I can politely inform people in the pub that they are wrong. I bet most people don't know that the case can be a functional component. Cheers chaps.
Reply to illegal to open case unless gsr in the Plumbing Jobs | The Job-board area at PlumbersForums.net
