M
mlgibbons
Hi
I'm sure this is simple but I can't quite figure it out. I have a stack that I need to vent using a AAV (McAlpine VP50P) which supports 110mm or 75mm pipes. I currently have the AAV inserted into the 110mm pipe and want to move it to another location using a smaller pipe but am confused about the pipe size that I need. Is it 75mm or 82mm? For 75mm pipe I apparently insert into the pipe into the AAV rather than the other way around for 110mm. I've researched it and my understanding is that 82mm pipe is 75mm internal diameter but in that case wouldn't the AAV says that it supports 82mm pipe? More than a little confused!
Mark
Mark
