Discuss Imperial gas meter has 2 lead output pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
ckyens
Hello all.
This post is regarding the configuration of outlet pipes from an imperial gas meter both pipes are lead.
A 22mm and a 15mm pipe branching off from it. Something I havent seen before.
Has anyone seen this configuration before?
Why the main pipe and a branch off?
Is it best to replace for complete copper pipes?
It appears someone in the past has connected the lead outlet pipes to copper pipes.
As the house has 3 appliances situated in different locations and as far as I can see under the floor
boards the appliances are fed by copper pipes not lead.
Any tips would be welcome.
Dude Gas questions. Get your details to a mod and we can help you. Not in open forum though
A lot depends on who you are and why you're asking the question, to be frank. Is there a leak? A smell of gas? Has someone told you that the lead pipes are a problem? If so, for what reason?
We can't give detailed, specific advice but in general terms we could steer you in the right direction, which may be to reassure you or to suggest you get a Gas Safe registered engineer in...
Has anyone seen this configuration before? YES
Why the main pipe and a branch off? GAS FIRE / COOKER maybe
Is it best to replace for complete copper pipes? Depends if someone wants to pay for it.
It appears someone in the past has connected the lead outlet pipes to copper pipes. Very common at one time, that'll be,, connected copper to existing lead.
For the rest see other posts.
I am Gas Safe registered. I uploaded my card front & back to the site moderators 3 weeks ago and the yellow badge hasnt been added to my profile.
Reply to Imperial gas meter has 2 lead output pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
