Discuss in a pickle in the Plumbing Jobs | The Job-board area at PlumbersForums.net
wanttolearn
Hi I'm fitting a new heating system right the way through a property before the boiler and last radiator gets fitted I wanted to test the pipework which I've already done.
I have already tested under floor boards etc that was ok
So when I've tested it after fitting all other rads I've lost three quarter of a bar overnight but I can only test it with compressed air as that's all I got.
I have been around all joints checking and nuts on valves but can't find no leak it's driving me potty
Any help on what I can do next as new carpets are being laid today
Hire pressure test pump failing that try get some mains water in it somehow via hose pipe if need be.
Water test is always best. Air is inaccurate, heat will affect your reading and you can't see a leak!
Most likely leak will be where your testing from . Pressure gauges are hit and miss too.
For you, now you have done a preliminary test with air, is to connect to water main and test. That will make any leaks show. Or hire a pressure tester.
Thanks a lot guys going to have to fill it up with water.
But going to test the gauge later to see if it that
Avoid air testing where possible and do a wet test.
I Always Air test where possible to check for any immediate leaks, Like an open end or bleed valve open, Did you remove the pump from your test gauge as the air hose will leak air out
If you used speedfit stop end it may have leaked thats why its always beat to test on compression stop ends with water
Reply to in a pickle in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
