Discuss Indirect Drainage Problem (without getting thru the floor) in the USA area at PlumbersForums.net
Hello all! glad to be here.... gonna be doing quite some plumbing work with a handyman of mine to lower cost of my new business so I hope this is the right place to get some good pro info!
So with my new biz, they are requiring a 3 basin sink like a restaurant kitchen, and with this they require an indirect plumbing for the drain of this sink. And the "official" doc states:
"Unless approved by the local plumbing authority, all warewashing sinks, culinary (prep) sinks,
ice machines, and commercial dish machines must be indirectly plumbed to a sewage outlet
pipe by either an air gap or air break."
Here is an image in our doc that shows an example and another photo the state office sent me as real life examples:
This is my dilemma... in my new space, the only thing that has any water access is the bathroom, which is hear the room where I want the 3 basin sink, just across a 3 foot space in the hall.
Initially I was planning on just drilling holes through the wall and connecting a pipe directly from the 3-sink to the bathroom pipes to flow into and drain out using a mini-water pump and adding a portable tankless water heater.
But a licensed plumber told me, and another agreed, that if we need that indirect drain, that is impossible, that we need to basically smash into and dig out the concrete floor, and run pipes into the ground and into the sewage line.
This will clearly cost me a TON more than my first option. In fact, quotes were like $3k - $5k ! (depending on any adversity with the concrete and pies underground)
So as the statement in the doc states:
"Unless approved by the local plumbing authority..."
can I use this to work around this? Example:
I find a plumber who can make this work WITH an indirect drain as shown, and use some contraption/setup that doesnt require us to tear up all the hard concrete and still get the job done, AND have a "local plumbing authority" approve it, thus, showing the city and Dept of Agriculture inspector that this is legit and will work the same safely?
Also I do not even know what a "local plumbing authority" is... I been asking my city hall office in charge of permits/inspecting and they have no idea either, so how do I find this "local plumbing authority"?
And I am open to ALL out of the box thinking here... This is a LEASED space and I really rather not be tearing up concrete to get this done, spending so much, since I already have to spend thousands on other parts of the space, it'll just get to be too much, even though at the end of the day, I am fully vested already in this and too late to turn back really.
Thank you!
Don't take offense, but if you were a plumber you would understand what the regulations state and how to implement them.
I'm not sure where you found the photo / picture of the 3 outlets connected into the drain, but that is not how to do it.
You have had advice from 2 plumbers, who say you can't do what you want to do.
I'm not sure how you will get around it if the plumbing gas to pass and inspection.
The only way would be the correct way!
OP states that the picture of the the three traps under three sinks was sent to him/her as an example of how it should be done. It looks OK to me apart from the vents. They will surely allow smells out from any stagnant water in the traps or from the sewer if the waste pipe is connected directly the other end.
JMASTERJ,
Can you upload pictures of where you want to get from, and what you want to connect the discharge end of the waste pipe into please?
Well I am clearly not a plumber LMAO so that's why I am asking, why would I be offended I am not a plumber?
That photo was sent to me by a manager who is the one that gives the green light for my business to be operational within their rules from the FDACS.
And the 2 plumbers DID NOT say I cant do it... THEIR only proposed solution was we have to tear the floor up to get the drain through the underground, but as I stated again in my OP, the document for my business rules state if a LOCAL AUTHORITY allows whatever design they deem works, then they can allow an exemption.
So basically again asking if there is ANOTHER correct way to do it... if u dont know, thats fine.
[automerge]1590045926[/automerge]
JMASTERJ,
Thanks, and FYI I will be using the sink so seldomly, I am not worried about scent or whatever else that comes from usage, it just needs to pass inspection basically.
Rough sketch...Bathroom on the right corner where the blue arrow is pointing...
3 basin to be on the other room on left in purple... Only water source and drainage right now is in the bathroom, so somehow want to route pipes that way I am thinking.
Someone else showed me an interesting setup, what do you think about this?
Reply to Indirect Drainage Problem (without getting thru the floor) in the USA area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the sink, dishwasher, washing machine etc. When I pour the concrete there won't be any chance to dig it up anymore. From my own research I get the...
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it is earthed. The new tap will use flexible tails and so will not be earth bonded. My initial search for information suggests that there is no legal...
