Discuss inhibitor lifetime in the Plumbing Jobs | The Job-board area at PlumbersForums.net
CXR100
I have bottles upon bottles of inhibitors, leak sealers , system restorers etc in my shed, all no more that a year and a half old, what kind of shelve life do they have? I want to sell the lot to make room
They are all no good now.
They will have moliculised and need disposing of..
I offer a disposal service and can arrange to have them relieved from your care for free :)
I had two bottles of Sentinel X400 which I purchased in the 1990's. I didn't use them, so they came with me when I moved house in 2006.
Four years ago I thought about using them but was unsure if they were still OK, so I emailed Sentinel. I received a reply the next day saying that, provided the bottles were still sealed, they would be OK.
They went in a little later, when the mid position valve was changed, and stayed there until the boiler was changed a year later. The water which came out when the system was drained was as black as soot, but there was no sign of sludge in the rads, i.e cold areas at the bottom.
Your supposed to put it in the systems you install not keep it for home use !
When I used to work for a company that did a lot of warm front installs they always supplied 2 bottles of cleaner and 2 bottles of inhibitor so 1 of each went in the other 2 went in the shed lol.
Reply to inhibitor lifetime in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper...
I have a pressure leak on my CH system. Our piping is buried in the walls (maybe a mistake) and the room-to-room pipes are now covered by flooring...
Oil boiler (now~15 years old) unvented system with 17 radiators. We moved in 5 years ago and I had to keep bleeding the same radiator. The bleed...
We live in a 1980s four-bedroom detached house. The time has come for new central heating. The current system is a mild revision of the original...
2K
I currently have a Vaillant ecoTEC Plus 438 system boiler which is 13 years old. I have been having problems with the boiler which potentially...
