Discuss Injector Tee - How to Make Up One Onsite in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anybody advise how to make up an injector tee without having to solder anything together? Tee being used is 22mm*28mm*28mm.
TBH it's easier just to buy one
Cut a 22 x 15 reducer down to a couple of mm . Insert this in the 22 end, with the 15mm part going into the tee. This leaves the 22mm end ready for the heating return.
Reply to Injector Tee - How to Make Up One Onsite in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
